Just went to take a look at my memory and saw that it said (memory capacity 122mb)!
Weird as i have a 128mb memory card! With my 16mb it says 15mb capacity!
Is this a bug or does the phone use some of the memory to load up or somethihg?
i know i read this somewhere
i think its the memory the phone takes 😃
10% of all memory "disappears" after format. Its the way file systems work. Like your harddisk. You bought a 15Gb drive, but it only says probably 14.9Gb. Its true for all storage medias.
Yep, formatted capacity is always less.
Wrong!
All memory or HDD manufactures calculate like this: 1Mb = 1000kb .
All systems calculate like this: 1Mb = 1024kb .
So all memory cards, hdd or whatever are smaller if you calculate like a machine.
ITS all ok,it should be so.i have 256mb CF for digital camera,but i can use only 254mb. :x
[quote="jimmy-floyd"]ITS all ok,it should be so.i have 256mb CF for digital camera,but i can use only 254mb. :x[/quote]
wow... you must really miss those 2 MB...
[quote="freakypriest"]Wrong!
So all memory cards, hdd or whatever are smaller if you calculate like a machine.[/quote]
you are partially right, but in the case of the 128, we would get 128000B/1024B=125MB, not 122, so.... WRONG[/u]
You guys obviously need a life
