Tripping The Rift
12 replies · 5,470 views · Started 25 October 2001
Tripping the Rift has probably been one of the favourite NIM's on the site, so I just thought I'd let you all know that the teaser for Tripping 2 has now been added to the NIMs - Cartoons section, have fun.
Patrick
www.n9210.co.uk
<B>Cool</B> User posted image
There will also soon be a request Tripping the rift Skin from me to all of you..Real soon..
(Futurama, Simpsons and Ren & Stimpy have also gone into production..)
But more on that later User posted image
_________________
User posted image<font size=-1>[ This Message was edited by Loonyworld on 2001-10-25 1051 ]</font>
Hi!
Patrick, I have a short mpeg humor video, but after use multimedia converter and save it on NIM format, then I can only see images, not animation.
Could I upload to you the video? Perhaps you can see what happen! User posted image
Regards
Yeah, no problem, zip it up and just upload it in the normal way. (has to be zipped as I've configured server to only accept limited file extensions.
Regards
Patrick
www.n9210.co.uk
Hi guys! I had to reinstall my commi (did it for a lot of times without problems) but now I can not play any nim videos any more. After starting video application and opening the nim-file, when I press the play button it says (File not foud error - something like that).
Some guess??? Thankx
Seko
Sorry, wrong name. It should by
Seiko
Greetings
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
Seko
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Try uninstalling Recorder (for audio) and Movie player and re-installing them (if your on 3.54 or above then make sure you use version 2.00).
Let us know if that helps
Hi there!
I reinstalled recoder and video but it didn�t help. But nevertheless I reformated teh system and set up everything new - Now it works.
Thanx again
Hi there...
Useualy when I encounter this problem i simply just overwriter the buggy media file..and make a quick reinstall of the player.. User posted image
That always does the trick for me..
Any news when the next episode will be available???
Great stuff by the way.... To be recommended if you need a good laugh.
Regards
Not sure, but tried to get on the TTR site today and getting message that the server is 2 busy - maybe it's on there, I'll keep trying.
Yes, me too. I want to the site. But it seems that no Links work, maybe due to his change of server... lets hope that new episode will be out soon, and much more...
Regards
