Nokiamultimedia converter help!!
2 replies · 2,374 views · Started 07 June 2003
Yeah, you have to get the Java environment download...
i believe there is a thread on this forum that describes your problem in detail.
Once you download the interface/environment you will be good to go.
hope it helps.
Ive just had the same problem you have to install Java Runtime Environment (JRE) version 1.4-1 or higher
