well i put my fone on keypad locked and all that. but suddenly when i get my fone out its off.
yesterday my friend rang me up and it just turned off. when i rebooted it lasted for a few secs. but when i got home and put the bat into my bros 8250 it booted fine with quite alot of charge on the battery.
now im talkin about a fully charged battery. but i think my fone doesnt last when people ring me up. but this doesnt always happen. this happens randomly.
:x
wat apps u got installed and wat firmware version u got? mite be a conflict between apps or mite be a glitch with ur softwatre version. try a hard reset. may find it was just a app. if problem still persists ur best bet is a nsc. hope this helps
i've had this problem with all phones i've had, the 7110 was the worst but the battery was loose, the 8890 just turned off on it's own accord, and i've noticed the 7650 did too, not always, not frequantly either though, i thought it would be more of a damaged phone or something like that, like if you jolt it heavily
as SAbz911 said it sounds like it need the software updated,
i just updated the firmware from 3.12 to 3.16 and ive only got stacker and a game called talon installed and thats all ive got. but i think this doesnt happen with the other battery i tried. so im guessin its some prob with the battery. :roll:
[quote="Anonymous"]as SAbz911 said it sounds like it need the software updated,[/quote]
It sounds more like a hardware problem to me. Why don't you take that phone to somewhere they can have a look to it?
