why does my 16mb mmc limit my downloaded ang taken pics to just 240 pics (the ones that can be used as wallpapers)???still have more than 3mb left of space from the mmc!!!!
16 mb mmc bug?!
maybe ur using the other 3 mb for apps or ringtones
Just use TASK MANAGER(psiloc.com)to check it.
When it says 240 pic's that is just an estimate, you may get more on there depending on the actual pix, depends on the file size.
Also you don't get the full 16mb after formating, just like any other storage device - you lose a couple of meg after formatting.
Best
Will.
