Doom on 3650 - Extra .wad files?
9 replies · 3,409 views · Started 10 June 2003
Can I run new .wad files on my nokia3650 like they are doing with the p800's? Anyone know?
Doesnt anyone know how to play the Doom2 wad on the 3650 version of Doom? Am I going to have to buy a p800 to truly get this to work?!?!?!?
You would be better off getting a 9210 then you can play all the wads in widescreen. As for running other wads, can't you rename the wads to doom.wad in the doom folder and have it run them? On the 9210 it uses the first wad it finds in the folder.
Are there any developers that can quickly take a look at what can be done about this problem? I would think many people who own 3650's would LOVE to be able to play Doom2.wad as well as all the others out there.....
[quote="SwitchBlade"]You would be better off getting a 9210 then you can play all the wads in widescreen.[/quote]
The P800 also plays Doom in widescreen.
Here's how the different versions of Doom looks:
Any serious developers willing to do this? I have many .wad files for Doom that would run great on the 3650, we just need a simple file conversion program to convert .wad files to .xwad!!!!
Anyone a serious developer out there????
Sorry to say, but those are not the drivers.. Only the sounds for the game..
Description from the installation package:
doom-sounds.sis - Sound data (optional - sounds will not play if not installed)
Sound can be enabled by installing one of our other games, which come with the required sound driver.
And the program containing the required sound driver is terraforce from wildpalm 😉
