Bluetooth
2 replies · 1,303 views · Started 10 June 2003
Hello!
I took delivery of my brand new Wavelinker Bluetooth adapter for my PC yesterday and was excited at the prospect of syncing my 7650 with Outlook.
It seems the only way to do this is to run the cumbersome Bluetooth manager that came with the Wavelinker, wait for that to detect my phone, then run Nokia PC Suite and sync them.
Do I have to use the Bluetooth manager that came with the adapter, or can I use any Bluetooth manager? If so, is there a cool one that will launch when I boot up my PC and minimise itself so that I don't even know it's there?
I'd like to be able to run Nokia PC Suite without having to worry about sorting the Bluetooth connection out first.
LittleC
I use the Billionton Bluetooth drivers version 1.3.2.7 with my Wavelinker. You should be able to find a link in the forums if you search for "Billionton".
It minimises nicely in the sytem tray and the method to get it working with the 7650 is nowhere near as cumbersome as that used with the original drivers, although it's still not as straightforward as I'd like 😞
[quote="littlecharva"]
LittleC[/quote]
If you set the synchronisation task in PC Suite to happen 'on connection' then you don't need to run it separately.
-Ciaran
