Memory stick
1 replies · 1,159 views · Started 10 June 2003
Is it possible to use normal memory stick instead of Memory stick duo. because i heard there is some mem stick adaptor along the phone
I just wanna confirm before i buy it
Thanks :roll:
Check this out (and you might consider searching next time first :roll: ):
http://www.p800er.com/product.asp?id=48
