Ok.. This is basicaylly one of the worst days of my life, this morning when I woke up I notice that my dog had just torn into pieces my new headset adaptor!!! I recently just got Unreal Player and last night I jsut loaded some new mp3s.. heres the story..
Last night, I was at my GF's house. I took out my 128 duo and plugged it in my 7in1 Card reader then copied some fresh new mp3s from my GF. I put the card back on my P800 then went home. I didnt test it anymore since I assumed I wouldnt have any problem. When I got home, just before sleeping, I opened Unreal player and noticed that it couldnt find any mp3s, feeling groggy, just said I will take care of this in morning. This morning, I plugged it in the adaptor, opened it on the PC and realized my MP3 folder was empty?? But the file size left on my MS was still the same.. I tried deleting the folder and it said it wouldnt allow me to delete it... So, I backed up my MS first, then I formatted my MS on the PC.. Lesson learned, Dont do this, it will screw your system up and your P800 will not be able to read your MSDUO! I experimented a lot to solve this problem, tried using another 7 In one reader with a different brand, even worst! My entire Audio folder dissappeared!!!
Anyway.. I was able to restore everything because I had this very old backup of my MS. Always back your MS! Then I placed my Mp3s on another folder oustide the "Audio" folder on the MS then placed it on my P800, then I noticed that all my ringtones were back. From the P800, using trackers file manager, I moved the folder with MP3s back inside audio and finally it worked. Unreal player cannot detect MP3s if they are not inside the Audio folder.
Cause:
I think the MS Magicgate duo sometimes triggers its protection and this either corrupts your data when you use a reader. Funny Thing is, I never had this problem before transferring MP3s..
Damn my dog!!! But I just love this pup.. So, I will order another adpator 😞 :cry:
