Just send 3-4 "flash sms" (those that - in other phones - are just shown on display and not saved on SIM) to the 7650 while it is turned off.
Turn it on... It receives the SMS and... BANG ! :evil:
"system error"
then it stops responding: only thing to do is to remove the battery
then you restart it... BANG! again... it won't work anymore :cry: :cry: :cry:
... anyone has any help?
receive the flash sms with an other cellphone by using you're sim.
If you're sure that you're phone should be able to receive these messages but just crashes because he's still loading, you could go to a place with no reception (a basement?) and wait until it boots up and then go and receive them.
hope it helps
the problem was: it already received the messages, so changing the SIM didn't work. Anyway, everything went OK after 9-10 restarts of the phone
but anyway it was a sad surprise to see such a bad thing 😮 till that moment I thought it was a bugless cellphone, the 1st one in months from nokia... :evil:
