MMC
5 replies · 1,313 views · Started 11 June 2003
hello 8) i have a MMC drive.but wen i instaled some softeare.i not found them in the phone.heelpp please
you installed software using an MMC drive? how did you do that? what software did you install?
if there's anything on the card, you should be able to see it by using any file explorer software...
Get yrself a WAP download of FExplorer from my-symbian. It's free and very useful. Once that is installed u can see every file on yr fone. Just locate your files on yr MMC (drive E) and click on them to install them. That is how i do it and find it a very quick and easy method.
That method is for app installs but obviously images and ringtones will be immediately visible without having to explore your files. 😊
[quote="J T"]Only if they're in the correct folders will they be visible to your phone.[/quote]
except if your using a file explorer software... or pc suite...
