Is there a key lock for the 3650 like with other nokia phones?
I cant find anything i the manual!
Keylock
Of course there is. Just press left softkey + * like in other nokias.
If you mean auto keylock, then you need Extended Profiles Pro.
If you want to block the phone so noone can use it (but still being able to receive calls and messages), press the power button and select "block phone" (or something like that - running the software in portuguese 😉
Well but is there any that locks the phone after a sudden time (i know there is an option for that in mp3 go)?
just use extended profiles bro......
[quote="macisback"]Well but is there any that locks the phone after a sudden time (i know there is an option for that in mp3 go)?[/quote]
Man, two post before you and you didn't even bother to read them? (Nothing personal.)
As i mentioned Extended Profiles Pro...
What rates better?
Extended profiles or SmartProfiles?
EPP freezed my phone.
SmartProlies didn't... but i didn't like it. :roll:
Mmm...
Playing with both.
So far i like smartProfiles more.
You can set an auto-keylock through Tools->Settings->Security->Phone and SIM, but then you have to type in the phone lock code every time to unlock it again...
[quote="energy"][quote="macisback"]Well but is there any that locks the phone after a sudden time (i know there is an option for that in mp3 go)?[/quote]
As i mentioned Extended Profiles Pro...[/quote]
Well nothing personal aswell, but sudden time means that you can edit the time till it locks. Couldnt find that in EPP
You can change the time on EPP too.
i've heard a rumour that extended profiles and smart profiles drain ur batt. quikly?????TRUE??????
SmartProfile will not have vibrator even if you've turned it on. EPP works well, but i noticed if u change the alarm sound, the original sound will still be heard for the first 1-2 seconds before your choice of alarm sound plays. And as usual, will get System Error once in a whilewhen attempting to change profile details. 😞
Cibenix ActiveToday also has an automatic/timed keypad lock feature.
