help -- oprator code!
3 replies · 2,188 views · Started 15 July 2002
hi guys,
need help -- anyone knows the operator code for Cingular Wireless, Southern California, USA?
been trying to send via emessaging, but can't find their code. TIA. 😊
You can try this... get hold of an old phone....like a nokia 2110 or something from the "ERA"..put ur SIm card in it & you will get your network code instead of a name.
Another way maybe to ask your service provider..... 😃
ciao
HyPeR
thanks for the response. i can't check it using your tip coz i'm not there... and checked out their website, no info too.
good day! 😊
Hi there!!
Try this one out:
http://www.gsmworld.com/roaming/gsminfo/net_usbe.shtml
That would give you the code 310 150, 170
Let me know if it has helped you, please
