Installed few applications but when I re-started i am only able to see and use call list. Rest of the applications can neither be seen or used. And i am really pissed 😮ops:
Could anyone help me out soon.
Help shall be appreciated.
There are several fairly straight-forward solutions (don't worry - it's a known bug and scares everyone the first time it happens). Some say removing the MS Duo and re-inserting it works, there's a program you can download that fixes it. Personally, I just turned the phone off, removed the battery, left it a moment or two, turned it back on and everything was fine.
Hopefully it'll be fixed in a forthcoming firmware upgrade.
Thanks a lot. Really appreciate yr. help
:bday: 😃
[quote="Bassey"]There are several fairly straight-forward solutions (don't worry - it's a known bug and scares everyone the first time it happens). Some say removing the MS Duo and re-inserting it works, there's a program you can download that fixes it. Personally, I just turned the phone off, removed the battery, left it a moment or two, turned it back on and everything was fine.
Hopefully it'll be fixed in a forthcoming firmware upgrade.[/quote]
