Loudest Of Them All !?!?!?!
13 replies · 2,225 views · Started 11 June 2003
since there are tons of ringtones available online for 7650, i wanted to know which one is the loudest of them all. in any format either .wav,.mid or .amr. currently me usin the standard nokia DRILL ringtone. if possible plz upload if u have a loud tone. and also i wanted a car alarm lock (beep beep) tone to use as a msg tone. some guy on this site asked for it guess he dint get it.
i know wav is the loudest i guess u ppl dint get wht i was askin. i wanted the file which ppl thought was the loudest.i dont mind a small wav file plz upload if possible or send to my e-mail. thx. Jesse
Depends on the quality of the original recording if you are converting something to wav. Some midis are much louder if the wav has too much going on to begin with
i meant names ppl. like (drill, nokia tune, espoinage, in tha club) like that there are tons available so whts the loudest of them all since ppl been usin 7650 for 2 yrs now... 8) 8) 8) 8) 8)
Found a great way to increase the Volume of Midis/Polyphonics if you have Ringtone Studio.
Except for Drum (Track 10) you can Duplicate the tracks.
If you for example have a Song with 5 tracks you can Dulipcate them so you end up with each having 2 Duplicate tracks equalling 15 tracks and the drum track. (Total is apparently 16 Tracks)
Try It, It Does Sound Lounder!
(If you want I will upload 2 Midis I have done. One with Duplicate Tracks and another without so you can see or hear the difference)
