Firmware? or File under b
3 replies · 1,451 views · Started 11 June 2003
I�m getting sick of my 9210! After a while I will get error messages like message watcher and sometimes fax watcher the only cure I can find is to re-format the whole thing and start again setting up the device and installing all my software which as you know can take days. After a while the same things happen programs not found and then the message errors. My firmware is old at 3.18, is it just the firmware causing this to happen all the time? If so does anyone know how much a upgrade is in the UK?
Many Thanks
I 2 have v3.18.
I don't have those messages a lot ...
Just sometimes when I've played with my inet and email settings to much.
I have no idea if a firmware update could fix this ...
I started with v3.18 and upgraded thru 3.62 to 4.13. While I didn't have the problems you described, I generally found v4.13 to be better and more stable.
If u r still in warranty, firmware upgrade in the UK is free under warranty. If out of warranty, the minimum charge from Communicaid (the only people here who can do it) is �150.
