3650 and Apple Quicktime
2 replies · 2,206 views · Started 12 June 2003
Hello all !
I have Quicktime Pro and have tried to use the 3GP part to compress a 30min movie for my 3650. On export the audio options are grayed out ! It says there is no audio to encode. :evil: But the original has audio on it ....(its a MPEG)
Any ideas ? My 128MB card needs films...
Hi
You need to demux mpeg movies to separate the audio and sound. Go to the apple website and view the quicktime support discussions. There is a great deal of info and they will direct you what to do. The profgrams you will need are available from versiontracker.com bbDemux and soundApp. Both these programs will convert audio, that you will then need to import back into Quicktime Pro and export in a new movie. It is a bit of hard work, but to have movies on your 3650 is worth it! I have just encoded full lenght DVD's and the morning train journeys now just fly!
. . . another way to make morning train journeys fly is Bust-a-Move 4 on your 3650! 😉
