Attaching sound to video
3 replies · 2,942 views · Started 13 June 2003
Help! How do attach a sound clip (i.e. music) to a video clip? I've tried it as e-mail, but they just get sent as two separate items, rather than a coherent whole. (I already downloaded the video camera format, that allows one to record the sound with the video as it happens.)
And what camera format is that? If you are using the official camcorder from Nokia all you need to attach is one file,the .3gp.
If you are using ETICam,i think there is send via e-mail option.
I'm using the updated video recorderthat comes with the 3650. But I just don't see anyway of attaching the files together. Where do I need to go on the phone menu? Under the video recorder? (Sorry for being such a dolt about this, and thank you for the reply.)
Well,the video recorder from Nokia has a send via e-mail option.That should work just fine.
Options->Send->Via e-mail
