help ive downloaded to my phone a wav file and a midi but when i select them as a ringtone in profile and the phone rings it just plays one of the default ones . i tried putting them on the mmc and the phone but no luck , they worked fine on my 7650
ringtone help
check what profile you have your phone set to.
you might of selected on a different profile and are using another one
eg... ring tone set on normal profile, profile curently using outdoors.
ive sorted it now , what i done the first time was use the pc suite but then i transfered the file from my pc without using the 3650 suite and it arived in my inbox and now works a treat
I have this bug :x ,but it appears when i transfer *.mid on MMC
