I've made a gui for 3gp to avi conversion..
check it out
http://www.mitsoftware.com/akiles
enjoy!
Mike
Spain
check it out
enjoy!
Mike
Spain
Doesn't work bud. 😞
Just says "working...." then a couple of seconds later "error".
I used the relevant version. 😊 3gp2 for my vid rec with sound. Maybe it has an issue with windows 2000 xp?
same problem here...working...then convert error
[quote="Miquel Taule"]I've made a gui for 3gp to avi conversion..
check it out
enjoy!
Mike
Spain[/quote]
[quote="rdollars1"]same problem here...working...then convert error
check it out
http//www.mitsoftware.com/akiles
enjoy!
Mike
Spain[/quote][/quote]
Sorry to say that this software is a royal piece of shit.
It's better to republish it when it's atleast nearly working. x
same here, can anyone solve this ?
If you have the videos in a file
e.g. C:\videos
have the converter in the same folder. and remove the brackets from any videos like video(1).3gp so make it like Video1.3gp
then convert it to a folder like c:\videos\avis
or something it will work.
well thats what i did and it worked. before that i had the program on the desktop and the files with brackets.
hope it helps.
Guys its very very simple:
1: Put the converter into C:/ (dont know if for example D:/ will work)
2: Make a Hyperlink from this program and place it on your dekstop!
3: Put the *.3gp files also into C:/
4: Start up the program and search for the *.3gp into c:/
5: Type in a name for the *.avi movie
6: SAVE IT IN C:/!!!
7: Click convert
8: Voila you have now a *.avi file
ptmbradley wrote:Doesn't work bud. 😞Just says "working...." then a couple of seconds later "error".
I got it working when i put the application in the same folder as the input and output files. (i put it all to c:\)
But the files size was major... The 3gp file was 5,4MB - the avi file was 209MB :P
I put both the .3gp file and the converter in c:\ still get the compile error!
Any ideas
Just make sure there are no spaces in the paths!
For example C:/documents and setttings..... won`t work.
C:/MyVideos will.
When I downloaded it, and tried it, and copied the .3gp files to my C:\ drive, no brackets or anything, I click convert and - this error message shows up-
CONVERT caused an invalid page fault in
module CONVERT.EXE at 017f:004020e6.
Registers:
EAX=0064f794 CS=017f EIP=004020e6 EFLGS=00010202
EBX=0064f794 SS=0187 ESP=0064f730 EBP=0064f740
ECX=00000004 DS=0187 ESI=00000000 FS=4db7
EDX=00000001 ES=0187 EDI=00000004 GS=0000
Bytes at CS:EIP:
66 f7 46 0c 0c 01 74 08 8b 46 18 89 45 14 eb 0c
Stack dump:
00a90dfd 00000000 00000000 00000004 00000000 00401251 00000004 00000001 00000004 00000000 0064f7f0 0040d0fc 0064f7f0 0040d100 00a90dfd 0040d108-
any help????
rohit
rohitkhannak45 wrote:When I downloaded it, and tried it, and copied the .3gp files to my C:\ drive, no brackets or anything, I click convert and - this error message shows up-
Registers:
Bytes at CS:EIP:
Stack dump:
any help????
rohit
Just find another converter. Helpful.
This prog helpt me... Works very good 😊
