Ximplify, a very friendly and prodessional, EPOC developer have released a new version of their leading product. myList version3 is now available and it comes in Pro and Lite versions.
Here is a brief summary of the differences between the two applications:
myList Lite:
[list][*]Single pane, single column outliner - maximum of 255 characters per item
[*]No Memo view
[*]Ability to link files but NO attachment or embedded objects
[*]No sorting function
[*]No horizontal scrolling
[*]Minimal support for CSV import i.e. one field and text only[/list:u]
myList Pro:
[list][*] 2 pane, 4 column outliner
[*]Support of up to 4 columns with choice of Description, Priority,
Date, Date & Time, Duration, Integer, Floating, Yes/No.
[*]Memo View - unlimited length, with support for rich text format
[*]Support attachments and embedded objects
[*]Sorting (for all columns and types)
[*]Full view scrolling, layout and dynamic column width adjustment
[*]Extended support for CSV import[/list:u]
The new version is very impressive, most of the new development has gone into the pro version and that is reflected in its $30 price tag (the Lite version at $18 is also good value). This may seem expensive, but this is a very flexible application and has many uses beyond the obvious list keeping - some of these are showcased on the Ximplify website; where you can also download trial version of both and see some screenshots.
If you haven't looked at this software before I would personally recommend that you do so.
