Anyone know how to use Launcher Skins?
6 replies · 1,990 views · Started 14 June 2003
cooler43 is right and you might want to check also this program called skineditor, when you install it then send the skin to the phone via IR and it will show as a message in the inbox skineditor can scan skins from the inbox and voila you could edit it and save it to it's right location i.e. phone memory or mmc card.
[quote="crypto"]cooler43 is right and you might want to check also this program called skineditor, when you install it then send the skin to the phone via IR and it will show as a message in the inbox skineditor can scan skins from the inbox and voila you could edit it and save it to it's right location i.e. phone memory or mmc card.[/quote]
is the skin file in .skn format? cos i tried to send it via bluetooth but it doesn't detect at all even thou the skin file is in my inbox. 😞
I went to settings and hit skin and it says no data. Where do i put my skn file? I dont use bt i use a mmc reader. Help!!!
