large 3gp-files
4 replies · 1,572 views · Started 15 June 2003
I can't play 3gp-files that are 5mb or 6mb.
Why???
The phone just stops....
ps: I'm using the realoneplayer.
Are you able to play them at all or do you get an error message when you try to play it saying the file is too large. I cannot help you in any event as I get the message the file is too large. Do you have automatic scaling on or off in the Real One Player's Video Settings?
I can open the files, but nothing happens.
It seems like the phone is loading, but it can do that for an hour, so I have to turn the phone off....
I don't get any error message.
I had automatic scaling [on]. What does that mean??
Anyone out there who knows what I have to do???
Please tell me how you do it..! 😉
I have read that people her play 30mb and 50mb movies on their phones....
Can you please tell me what I'm doing wrong?
Must I use another program?
Or does it work with the realoneplayer?
i personally suggest just getting nokia's multimedia converter. it is insanly easy, and produces compact files. there is also an option to say "dont go over X ammount of Kb.", its really excellent. it comes out in the 3gp format. i also had the "file too big" problem with a movie, but i re-encoded w/ nokias software and it worked. thank jebus
