I am using nokia 7650. It is a nice phone....accept the low volume. The ring tone is very low + whenever I use handfree, I am not able to listen properly. Can anyone guide me what to do......is there any software to improve the volume level......if yes where can I get it?
Ring + handfree volume
use the search button on top, there are tons of thread on this. buy ringtone studio to make tones louder. .mid format ones... and for the handsfree theres a small simple trick
There is a simple trick to get around this. Try making a call through the voice tag option. Use a name which is not stored as a voice tag on your phone. The phone would give an error like voice tag not found or something. Now try to check the volume....it should have gone up considerably.
CJ
cj99 wrote:There is a simple trick to get around this. Try making a call through the voice tag option. Use a name which is not stored as a voice tag on your phone. The phone would give an error like voice tag not found or something. Now try to check the volume....it should have gone up considerably.CJ
just joined the forum today and you saved me a trip to the repair shop.
thx so much 😃
Kenny
