Composer problem!
0 replies · 1,043 views · Started 16 June 2003
I have a problem with the pre-insatlled Composer application on my N7650. I didn't use the application from my last SW upgrade, but I tried and I constantly receive COMPOSER: System Eror, if I try to create a new .rng tone!
I tried to open the .rgn tones with SeleQ, but was surprised, that I can open .rng files only if they are not bigger than 25b in size. If I try to open a .rgn file bigger than 25b I receive :Composer: unable to open file.
Any ideas what is wrong with this application.Is it possible this application to be affected by some other installed applications( third party), even if it is on the ROM?!
Is there any way to install the original Nokia Composer application again?
BR, Miro
