Extension and security problems with 7650
6 replies · 2,504 views · Started 16 June 2003
Anybody can say what type of extension is APP??? When i try to open one of these files the phone say it cant open for security problems....!!
Thanks a lot
nokia is not using programs like microsoft does instead it uses symbian. If you install an application for the nokia most of them ends with sis, jar and sometime jad.
[quote="Maveric"]nokia is not using programs like microsoft does instead it uses symbian. If you install an application for the nokia most of them ends with sis, jar and sometime jad.[/quote]
.SIS ----> Is the Application installer file.
.APP ----> Is the running file of an application
.JAD ----> Is the executable Java MDIP
.JAR ----> Is the .JAD descriptor
