Hi i have the camcorder app but i was wonderin how can i get my clips onto pc and then wot software would be used to play em
Camcorder app
send thru BT iR or email (to ur self) veiw the with the mm player on the 3650 cd or use mmc converter preview section adn watch...
ok yea i transfered it thru BT but when i ry to play it thru nokia MM player i can only hear sound... plus there turns out to be more files for it after for somereason...
theguidetoall wrote:removed
Geesh watta suckass. :tongue:
Kamalayan wrote:Geesh watta suckass. :tongue:
Yes,he was a suckass,so i deleted him. 😉
fearce wrote:Hi i have the camcorder app but i was wonderin how can i get my clips onto pc and then wot software would be used to play em
what camcorder app is it? im after one for my 6600 cos its crap that you can only record 10 seconds
Search the forum
