Dominique just released the new version of his FileExplorer! Just read on to find out about the tons of new improvements or head to www.gosymbian.com straight away to get it!
FExplorer V1.10 of Juni 13rd, 2003 !! READ BEFORE !!
what's new :
* a message is displayed when a screenshot is saved.
* added the time in the properties of the files and the
date and time in the properties of a directory.
* the number of the last screenshot is saved and continue
with the next version (to avoid overwrtting).
* the icons associated with the files (if so) are now
displayed in the list.
* you can now turn the infrared ON from the Tools menu.
* I have improved the quality factor of the images captured
with the screenshot, the image is now captured at
176 x 208 instead of 176 x 188.
* it's now possible to run the .EXE files (not only .APP,
ex: to run console applications).
* in full screen mode, the size (free/total) of the drives is
displayed at the top of the screen if activated.
* before exiting FE, the last directory is saved for the next
use if selected in the settings.
* the network info box displays also the area id and the cell
id.
* when exiting the editor-viewer, the previous path is kept.
