Synchronize and DXPPIM~1.EXE error...
7 replies · 2,216 views · Started 17 June 2003
:cry: I use the toy with WinXP and synchronize no problems. I've started sync'ing it in work as well but the work PC will sync once or twice and then gives DXPPIM~1.EXE error and sync stops working. sometimes a reboot gets it going, if not then an unistall/re-install will get it going for a few sync's then away it goes again.
Both PCs use Office XP but the failing one uses W2kpro not WXP. P800 is latest upgrade R2F etc; PC Suite is also latest v.
Any of you guys had this prob?
Cheers and God bless, The_Hog_Rider...
😮ops: 😮ops: 😮ops: 😮ops: 😮ops: 😮ops: 😮ops:
Typical engineer, doesn't check the simple stuff first!!!
Work PC hadn't had SP3 or hotfixes etc. applied - it does now and all is sweetness and light :fadein:
