I'd like to transfere data from/to my nokia 7650, but I have
succeeded in it only by using the "PC Suite" and backing up/restoring the
image of the phone :cry: throughout my Bluetooth connection.
Do you another way to do that ? 😃
Thank's ....
Trick Lo.
Sending and recieving files via IR has worked well for me.
[quote="Anonymous"]Sending and recieving files via IR has worked well for me.[/quote]
Ok I've succeeded with a new BT card. My first try was with
the ComOne Bluetooth card M310 (a PCMCIA card), and the Send File
feature was not possible From/To the Phone :evil:
Now, I'm using the 3Com USB Adapter (3CREB96-EU) and it's working perfectly ! 😃
So if you want to do this, be careful before purchasing any BT card/adapter. 😉
Trick Lo.
