Hi! I will be getting my new 128 memory stick duo soon and upgrading my firmware soon as well. I know that i can restore from destop to my phone but if i restore using a new memory stick duo 128 MB rather than my previous 16 MB, will all the application eg. opera which i installed on the previous 16MB be restored to the 128MB as well? It will be a hassle if i have to install the applications manually one by one again. Hope to hear some advice soon! Cheers!
Restore on upgraded phone with new Memory stick duo
There will be no problem to restore on a larger Memory stick Duo.
I have tried restoring after firmware upgrade and master reset. You will lose voice command (if you recorded before) and possibly need some fine tune on your internet connections. :-?
Alritey! Thanks dude! Will just do that! Cheers!
