Our company has developed an instant messenger for Nokia 7650 & 3650
that is compatible with ICQ, MSN, AOL & Yahoo!
We are currently looking for Beta testers who can try our product and
provide us with feedback.
If you are interested in becoming a Beta tester please email us at: [email protected]
Just out of curiosity; Did anyone get this app and tried it out ? 😉
yup, i did. And it works great.
I've allso tried it, but i don't know how to use it... And why does it not ask me what connection to use?
ive got the full version of im+ adn if i wnat to connect msn my phone says ive got the wrong sever does someone know witch sever or conniction i need???
@Timon
I really really really need your help. I cannot get the app to work for me and I have no clue as to why. I can never get aol working because it says something about a server error. I get yahoo remote host error messages. ICQ works sometimes. I can't tell you how many times I've installed and uninstalled this app from the phone. Lol, I dont think the application likes me!!!!
lars.
for IM+ and MSN you need :-
host: login.icq.com
port: 5190
then your login username & password
Will.
Will. Lars was asking about msn.. Not ICQ.
Will what you described help you connect to msn?
I do not use IM+ and therefore can't help out. sorry
Ok, I'm completely giving up. I've posted here and in a seperate thread, emailed the owner about the app, filled out that online form for the beta testers and STILL haven't gotten a response. I guess my next bet would be to just use IM+.
Just an update... Agile is finally working on my phone!! YAY!!! But my next problem is that I upgraded the version so now I have the cute little icons, but no sound. Any way to change this??
In the updated version there is an option/settings part (have not installed it yet, after my update :-/
But in there you can choose to have a sound. (no standard sound with agile this time) So you have to find your own sound for it 😉
Hope this helps
That worked!! Thanks!! I had my phone on silent when I tried before and thats why it didn't work.
The only problem i have with the program, is that it shows when ppl are online, but it does not show when they are "away." It just says they are offline. Im not sure if thats just me or if anyone else has the same problem. But other than that it works fine. And it would be cool if you could get the file transfer feature.
Hmm.. I would prefer to be able to set my status as invisible and be able to set people on visible/invisible list. Getting that feature would really ( in my world ) Make this product cool 😃
