Hi all. After my R2F upgrade. I found out that they have install games like solitaire and chess and demo. Only problem that even when i go to control panel to uninstall, i couldnt see them in the uninstall window. So more or less iam stuck with games and stuffs i dun need and taking up my memory. Anyone can advice me on wat i had mentioned....Thanks....greatly appreciated if any of you guys can help
Cheers!
Uninstallation
Hey
Yoy nedd to get the disc that came with your P800. Install the games again on the c drive. When you have done that, then you can uninstall them from your control panel.
Funny, but that's the way to do it.....
Heys guys, dont be afraid to do a search before making a post that has been dealt with before...
Refer - http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=13420
tHANKS DUDE! will do that!
No worries Astroboy77, trust me, there's HEAPS of information in all the previous posts 😉
