Hmmm... Sent a few images from the phone via BT just now...
5 replies · 1,758 views · Started 21 June 2003
Does anyone have any idea where the images were saved to? I checked the ftp directory and they're not there. Am I just sending it to dead air??
Go to "my documents". There should be a folder named "bluetooth exchange folder" or something similar.
Ok try this: Open "my bluetooth places". Open "bluetooth"->"advanced configuration" from the pulldown menu. Choose "local services" tab, select "file transfer" from the list and click "properties". There you should see a input field where you can define the folder where your files are stored when sending via bt.. I'm using XP so it might be different with 2k.
Hope this solves your problem
