Virtual Flip Up, Lights out?
14 replies · 3,410 views · Started 21 June 2003
Whenever I put the virtual flip up, backlight goes out after 10 seconds and not matter what button I press or scroll, lights donht come back on 😞 But when I open the virtual flip(back to pda mode) lights go back out 😞
Ligts are set on auto. If they are set on always on this doesnt happen, there is just a dimming effect but when I move something lights brighten up right away.
Help.
Yup, I noted that too since I upgraded firmware to R2D and also installed unrealplayer...so I am not sure if it is firmware upgrade or the player..don't wanna uninstall player...however, it doesn't happen all the time.
Had this once, turned the phone off and on again, and the problem was gone...
P.S. I also have R2D and UnrealPlayer installed...
I also have R2D and Unrealplayer so will experiment... I have turned my phone off several times already and still have the same problem..
Had this problem too and like others here with upgraded firmware and Unrealplayer.
To make it work, I turned off the power but when I turned it back on, light was completely gone! I went to settings and now light was set to off even though it was set to on before turning the power off! So far, I have had to turn off the power to resolve this approx. 5-7 times - each time I have to go and set light from off to on.
I haven't really been looking for the source of the problem but it seems to happen whenever I have unanswered calls and unread messages at the same time. First I am asked if I want to view my new message and even while answering yes, I am prompted to answer if I want to view unanswered calls and I have no other way to view the new message than by viewing the unanswered call and then go to the main message app!!
Anyone?
[quote="sidneylopsides"]it was 1.2.1 that i installed and got the lights out problems![/quote]
Have you trued restarting you phone?
[quote="sidneylopsides"]no, i just unistalled unrealplayer! 😃[/quote]
and did you get rid of the lights out problem?
