Display is Fading
6 replies · 1,687 views · Started 21 June 2003
I have had my 3650 since April. The display seems to be fading and not as sharp or bright as before, especially when I take pics with the built in camera--the quality seems worse then before--and videos are also not very clear. These are still the built in apps. I have not messed with the contrast. Does anyone else seem to have this happening?
Sometimes,during the day,when I use my phone outdoors and the phone is protected from direct sunlight but there are good lighting conditions I can notice darker areas on the screen edges.This does not happen with artificial lighting.
I had the same problem, but I went to Nokia Club Service and they re-install the software, it was because of one program " I can't remember what program was " but they said that was because when I did the uninstall, the program deleted a system file
So go to a nokia club service and re-install your software peter
i dont think the 3650 is as good in nightmode as 7650 when looking at the screen its same but when you click the shot it goes real dark
