help me please
10 replies · 1,991 views · Started 22 June 2003
help please ireally need help my nokia 3650 system error every where igo in the menu in the camera every where so please help me my phone was great but when i installed wild skinz i dont know what happen so please help me :cry:
That hapend 2 me also when i installed a crackd wildskinz.Better delete it
😊 i already delet it but now isolved the problem i restarted my phone and now it is like a new phone
You get what you pay for. Treat yourself to some good software, spend a few bucks (the cost is the same as a few beers at the pub).
try to remove the MMC then check if the system error still appears on the screen. if it doesn't, then your MMC might be corrpted. try reformating it if you can. it after reformatting the MMC and you are still experiendcing the same issue, better change your MMC then.
[quote="jimmy-floyd"]TRY to unistall Wildskinz,remove Smart launcher,and REMOVE ALL CRACKED progs..[/quote]
I JUST WANNA ASK IF YOU KNOW HOW TO REFORMAT
THE 3650 PHONE?
ok, this is how you do it. however, if you're experiencing system error already, it is not recommended to back up the files anymore, i.e., applications, games as you will just experience the same issue once you restore all of your phone data. here's how you do it:
1. be sure that your phone has ample power supply. or better to charge your phone while doing this procedure.
2. from standby mode, key in *#7370#.
3. it will then ask you if you want to restore all original phone settings.
4. press ok then enter your lock code.
5. phone will restart.
note: this procedure will delete the entire content of the phone and will restore to it's default settings.
[quote="jamella"]note: this procedure will delete the entire content of the phone and will restore to it's default settings.[/quote]
Everything? Contact and Calendar too? Can I at least backup my contact? Which file is it?
hi,
i have read in the forum, that u must reinstall wildskin, deaktivate it, and then remove it. then ur phone will be stable.
u can backup ur phone memory over the mmc menu in the extras folder.
cya amigappc
