Anybody know where to download nMM Nokia for convert mp3.avi
3 replies · 2,189 views · Started 23 June 2003
Anyone know where i can download nMM Nokia (Nokia Multimedia converter) for convert Mp3 or avi, i try to download from the Nokia website but the program in there is damage. if anyone where i can get that program please tell me that site........ thanks
disable your download managers and try to do a normal download. the software downloaded from nokia works fine for me...
I already try it, but the software can't use either the download is finish but i can open that Zip file!, are u try to download that software? the other work fine to for me. if you have that software (nMM Nokia) can u email me at [email protected] plssss............. thanks 😃
