after my 4 yr old had been playing with my 9210 1/8 th of the left hand screen is greyed out with a defined straight edge.i have rebooted and it has not cured it at all.some of the grey is diffrent shades has any one any ideas at all.much appreciated if u can help :cry:
any ideas here?? please
Is the screen cracked? Probably he broke our screen... :cry:
...your screen... 😮ops:
the screen and outer case is ok .everything is working but when using menu only half is seen due to this.he did say he might of dropped it on a hard floor.kids!!!!!!!!
has anyone any idea if it is the screen the best way of replacing it etc cost and by who....
thanx
I know that the screen is expensive and it takes some time to have it repared! If your 9210 is still under warrantee try to convince the nokia service people that your screen was fucked up by itself...It's worth the try! 😉
P.S.
You should only get it repaired thoroug a Nokia service point because the pieces are under warrantee...u should find a nokia service point where u live... 😮 U live in europe?
LOL
about the screen in my country last time i checked it's about US$200 which is around half of the price of the 9210i
unfortunateley not under warranty.uk,
Anyway,try check with a nsp...let us know... :roll:
nsp ???
i think Nokia Service Centre
or kind of that 😃
cheers all
[quote="n1ghtFLY"]i think Nokia Service Centre
or kind of that 😃[/quote]
You got it... 😉
Well, if u ask me... its already due for a full replacement!
Get a new one. Trust me ud fill better.
I know d pain of looking at a communicator dat is already bent out of shape and seeing others in rather healthier cnditions!
Jst dnt leave it w ur kids agn! cnt blame them, they r kids! 😉
Bsyds, even thou there wil be parts avail & d service is cheap, it doesnt realy mean that ur communicator is as gud as new, ud jst be dissapointed finding out dat its not money well spent for half of it when the other drawbacks or defects kicks in!
Well, this is of course jst my opinion! 😉
[quote="The Godfather"]😃[/quote]
What u laughn at??? 😃 😃 😃 😉
[quote="heyyhowudoin"][quote="The Godfather"]😃[/quote]
What u laughn at??? 😃 😃 😃 😉[/quote]
Because you gave a good advice 😉
oh! 😮ops:
thanks! 😃
