With the flip closed on the P800, is there any way of changing the shortcuts available if you select "Applications" from the five circles?
On my P800 currently, they are:
1. Communicam
2. Messages
3. Contacts
4. Calendar
5. Tasks
6. Jotter
7. Voice Memo
8. Online Services
9. Connections
I know how to change the normal shortcuts, but I can't find the info on how to change these anywhere.
I realise it's probably been covered elsewhere, but I really don't have the time to read through everything. Please don't flame me!! :cry:
I don't think it's actually possible to change the list displayed under "applications" in FC mode, just changing the actual applications behind the five icons(Control panel - Flip closed shortcuts)... I might be wrong though, don't use it much in flip closed..
I dont know how but my number 9 has become unreal player already! Its either it get the recently used ap or, unreal player places it ther automotically.
the OS goes out and does a search for all the applications that can run in flipclosed mode then lists them here. the order in which it searches causes the SE apps to appear first.
since unrealplayer supports flipclosed mode, it will get listed too. user apps usually appear the end of the list.
