The USB connecting thing
9 replies · 26,863 views · Started 24 June 2003
as mine doesn't wanna get the phone to connect even though it's active and reserved on com 7, and detected on com 7, can i get a smartcard reader for my pc which will let me create files and move files into folders on the memory stick? coz to play mp3s using unreal, i need the mp3s in their own folder and not unfiled, but i can't do this on the phone and definately have no access to it on the pc, would it work then?
Hmm, strange that you cannot connect.. Did you try uninstalling/reinstalling PC-Suite? Did you upgrade to the latest version of PC-Suite(available on the SE site)? What is your PC OS?
You can use this free P800 file manager, or this PC file manager or the file manager in Tracker, to move files from the "unfiled" folder to the folder of your choice.
Or better yet, as you already mentioned, get a Memory Stick reader/writer when you want to transfer big files. I have one of those multible card reader/writers and I can tell you that the transfer speed is more than 10 times faster than using the cradle or IR/BT! 😊
it is weird, i'm using win xp, on the ericsson pohone icon in the taskbar, i double click it, and have com port 7 enabled because in the mrouter (nokias piano connecter) AND ericssons phone connectivity link, they both read that com port is the USB cradle, so i've enabled it and nothing else, and reserved the port for the phone, the cradble lights up when i plug the phone in, everything seems to be working except when i click on the p800 icon, it says not connected :'(
i've installed 1.51 off the net (the pc suite) and have tried reinstalling the bluetooth drivers again, they were found, but i was told that there's meant to be a phone connectivity setup to identify it on the computer, but this doesn't show 😞
i'l try those two links you have given and if in doubt, i'll get card reader, is it just a standard card reader? will it use that duo stick apadter which came with the p800 to plug into the card reader?
thanks for your help so far,
NK8
Sounds strange - but it could be a com port conflict. I had strange things happening when I wanted to install a bluetooth pc card for my laptop - there it turned out that - despite having reserved the port - I had com conflicts.
I suggest you try and uninstall your bluetooth drivers/devices AND try to physically disconnect all usb connected hardware. If you have a usb hub you should definitively try to disconnect it and connect the cradle straight to the usb root hub.
Installed Bluetooth software and USB cradle no longer detect phone! Uninstalled BT, uninstalled PC 1.5.1, reinstalled PC 1.5.1 still same problem...
Any more suggestions!?
The s/w that comes with the phone is just sh!te.
:x
this is the same with the nokia suite too for when i was using the 7650, they come bundled with shite for xp users
i've got the same problem with my sync station, the phone connection link
says its connected, yet when i use use any of the applications it says there is no phone connected. It works on occasion but its usually messed up.
I had similar problem last couple of days :evil: and then I uninstalled everything and installed from the beginning. The COM port thing is quite complicated (USB and Bluetooth) so I followed the following advice from Readme file. Now everything works fine 😃 You may have different bluetooth but the basic concept is the same. Hope it helps.
6.3 CONFIGURE P800 FOR PC CONNECT OVER BLUETOOTH
(SYNC, FILE TRANSFER ETC.)
Info:
When you connect a computer with P800 over Bluetooth then two COM
ports are involved. First the computer uses a COM port to connect to
P800. When this happens P800 will close that connection and open a
new connection, which will be used for PC Connect (Synchronisations
and file transfer).
Note: It is not possible to make a backup or restore over Bluetooth.
6.3.1 TDK BLUETOOTH USB ADAPTOR OR TDK BLUETOOTH PC CARD
Preconditions: Bluetooth SW and HW installed. PC Suite for P800
installed. Windows 2000, Windows XP or Windows ME.
TDK Bluetooth SW version 1.3.2.19 is used for this description.
If you are using another version it might work slightly different.
First you have to pair your phone with the computer. This only has to
be done once.
Phone:
1. Go to Control panel -> Connections -> Bluetooth -> Settings
and select Discoverable as Operation mode.
You can also give your phone a more personalised bluetooth name.
2. When finished tap Done.
A Bluetooth icon appears in the status bar on the phone.
Computer:
3. Open My Bluetooth Place (Found on the desktop or the right menu
in TDK Bluetooth icon in system tray).
4. Double click on My Device.
5. Right click on My Bluetooth Serial Port and select Properties.
Check which COM port is set. Remember this COM port.
6. Right click the Phone Connection Link icon in the system tray
7. Now make sure the COM port found above is selected.
8. Close Link Properties.
9. Go to My Bluetooth Place and double click on Find Bluetooth
Device (or Search for devices in range).
10. An icon will appear for each bluetooth device found. Right click
on the icon with the name you have given your phone and select
Pair Device.
11. Type a code for example �123� and then click Ok.
12. After a while a dialogue is asking for a passkey on the phone.
Type the same code as above and tap Done.
Now your phone and computer are paired.
The following steps shall be done when you want to connect your phone.
If you have just paired your phone and computer then your phone is
set to Discoverable. Normally when you like to connect the phone it
is recommended to be set to On.
13. In My Bluetooth Place right click the icon for your phone and
select Connect Bluetooth Serial Port. If this menu item doesn�t
exist then you shall select Discover Available Services. From now
you will have this menu item. Go back and select it.
14. You will get a Connection Request dialogue on your phone.
Tap Accept. The phone icon and the Bluetooth icon in the system
tray turns green to indicate that the phone is connected.
15. Now you will probably get a dialog telling you that the Bluetooth
Serial Port failed: The remote device closed the connection.
This is correct behaviour. (See the info 6.3)
16. If this is the very first time you connect this device you will
get a wizard asking for a name (Go ahead with this wizard).
Otherwise you are connected and a phone icon will show up in
system tray.
Now your phone is connected and you can start to synchronize or
transfer files.
Tip: You can also connect the phone from the system tray icon.
Select Quick Connect -> Bluetooth Serial Port
6.4 CONFIGURE P800 AS MODEM OVER BLUETOOTH
These chapters will describe how to configure different Bluetooth
products to be set up for modem use over Bluetooth. When you have
followed the instructions you are strongly recommended to install
the Sony Ericsson P800 Bluetooth (TM) Modem. (See Chapter 7 and 8)
6.4.1 TDK USB ADAPTOR OR TDK PC CARD
1. First you have to pair your phone with the computer. This only
has to be done once and is described in chapter 6.3.1 (step 1 to
step 12)
2. Open My Bluetooth Place (Found on the desktop or the right menu
3. Double click on Find Bluetooth Device (or Search for devices in
range) and then double click on your Sony Ericsson phone.
4. Double-click on the Dial-up Networking on <your phone name> icon.
5. Click properties.
6. If the dialog Bluetooth Connection pops up continue to step 8, if
the Bluetooth Properties dialogues pops up then click
Configure... and continue to step 8, otherwise the dialog Location
information is shown, fill in an area code (any number, for
example 1) and then click OK.
7. Click the Cancel button.
8. Note which COM port that is used for Bluetooth modem, for example
COM15.
9. Now click cancel to leave the Bluetooth connection dialog. And
click cancel again to dismiss the previous dialog.
10. Right click on the Phone Connection Link icon in the system tray
and select properties.
11. Make sure the COM port you got from step 8 is NOT selected then
close the dialog.
12. Open Phone Monitor Options found in the Control Panel
13. In the COM ports tab make sure the COM port you got from
step 8 is Enabled.
14. In the Setup tab. Select �Only display the icon when a phone is
connected� and then Click OK.
15. Wait until the Mobile Phone Monitor icon appears in the system
tray, (This can take more than 30 sec). If a wizard appears then
follow it to the end.
If you like to set up a Dial-Up Network Connection go to Chapter 7.
Otherwise you shall go to chapter 8 for description on how to install
Sony Ericsson Bluetooth (TM) Modem. Remember the COM port you got
from step 8.
7. DIAL UP-NETWORKING WIZARD OVER BLUETOOTH
installed. Windows 2000, Windows XP or Windows ME. P800 has to be
configured as modem over Bluetooth (See Chapter 6.4).
You have to know, which COM port is used for the Bluetooth modem.
It depends on the Bluetooth HW/SW. (See Chapter 6.4 how to find that
port.)
1. Go to Start -> Programs -> Sony Ericsson ->
Dial-Up Networking Wizard. (You don�t need to set the P800 in
Modem mode when using Bluetooth as described in the dialog.)
2. Click OK.
3. Enter a name for the dial-Up connection. For Example
�P800 Dial-Up via Bluetooth�. Click next.
4. Select GPRS or CSD/HSCSD. Click next.
Now we will install Sony Ericsson P800 Bluetooth (TM) Modem. If you
have already installed it go to step 12.
5. Click Install modem�
6. Click Add.
7. Tick the Don�t detect my modem; I will select it from a list
check box and click Next.
8. Select Manufacturer Sony Ericsson Mobile Communications and
select Sony Ericsson P800-P802 Bluetooth (TM) Modem. Click next.
9. Select the COM port used for the Bluetooth modem and then Click
Next. (The result will be that you have two Modems attached to
the same COM port. This is OK)
10. Follow the modem wizard to the end.
11. Click OK on the Phone and Modem Options dialog.
The Sony Ericsson P800 Bluetooth (TM) Modem is installed. Now we
shall select it.
12. Select �Sony Ericsson P800-P802 Bluetooth (TM) Modem� in the
Sony Ericsson Dial-Up Networking Wizard and click Next.
13. Follow the wizard to the end.
8. INSTALL SONY ERICSSON P800 BLUETOOTH (TM) MODEM
If you like to use your Sony Ericsson P800 as a modem it is
recommended that you install Sony Ericsson P800 Bluetooth (TM) Modem.
You have to know which COM port is used for the Bluetooth modem.
port.)
Info: This procedure can also be done when using the Dial-Up
Networking wizard. (see chapter 7)
1. From the Control Panel Click on Phone and Modem Options.
2. Click the Modem tab.
3. Click Add...
4. Tick the Don�t detect my modem; I will select it from a list
check box and then click Next.
5. Select Manufacturer Sony Ericsson Mobile Communications and
6. Select the COM port used for the Bluetooth modem and then click
7. Follow the modem wizard to the end.
8. Click OK on the Phone and Modem Options dialog.
Check for spyware.
Use the Program LSPFIX.exe and all your problems are solved.
