* ring * ring * HBH-35 vs HBH-60 in Singapore..Round 1..GO!
1 replies · 1,732 views · Started 25 June 2003
Both the BT headsets are now available in Singapore(http://www.mobilesquare.netfirms.com/Promotion.html),difference of only S$10.00, but just want to ask comments about it from folks all over the world who have owned it and comment on both of them. Would appreciate if those who have experienced using them to comment on both the headsets too.
I have HBH-60 (short stubby one).
Makes you look a bit like a Borg (as do all SE headsets),
despite the short arm, sound quality at the far end is apparently very good -- they do not realise that it is a headset and pickup from environmental sound is low.
Sound in your ear is fine, and you can hear through it, so no deaf side.
The range is far short of the promised 10m though -- more like 6.
Apparently most HBH-60's rattle when shaken, though nobody can explain why.
