Computer phone alert
5 replies · 1,984 views · Started 26 June 2003
Hey,
does anyone know of any software that allows you to have an alert on the computer screen (like new email msg) when your phone rings? useful for the office where it's on silent.
AJ
One possible answer is a Program called "Remote S60" which can display you 7650 screen on you PC screen (via IRda or BT).
Do a search on internet to find it as I couldn't find in Software section on AAS.
And whit it use AlwaysOnTopMaker so you will always see the S60-screen.
http://www.fadsoft.com/AlwaysOnTopMaker.htm
This nice small (6k) proggie is FREEWARE!!!
Blimey! Thanks.
haven't really had a go yet, but it's coming up saying the bluetooth port is being used by another program (mrouter). But I can't connect without that. Am I missing something?
Is there anything this phone can't do? Anybody got software to cook me dinner & cure hangovers?
AT
[quote="aj_thomson"]Blimey! Thanks.
AT[/quote]
I think you would have to use the mRouter software in task bar to disable access to BT to allow the Remote S60 software to work. mRouter is only for connecting to Nokia 7650 PC Suite software. You can re-enable when you need to use the software again.
[quote="Urpo"]And whit it use AlwaysOnTopMaker so you will always see the S60-screen.
This nice small (6k) proggie is FREEWARE!!![/quote]
Sounds like the perfect prog to use with my TV software so i can keep browsing with a full window.!
