Out is new messenger. Agile messenger
still in beta version.
but!!! is totaly better thatn IM+ or nICQ
many news and better implentation things
and ITS FREE !
ICQ, MSN, YAHOO = Agile messenger
great but... the link?
i would recommend getting the link from the creator, that way you can provide feedback. That is the reason for beta's.
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=14047&highlight=beta
Agile messenger is indeed excellent! I really recommend it to everyone 😃 I have tried ICQ and MSN and had no problems at all. It even gracefully handled a lost GPRS-connection by simply reconnecting. Impressing!
Yes totaly good soft. but i mailed to creators that someting will be good in new version.
support for fulscreen mode
user setuped incoming sound
file sending
status changing for ICQ (now not work good)
I have to correct myself a bit, hehe. I just discovered that the Swedish characters ������ don't work using ICQ... However, they work using MSN.
This messenger are using UNICODE !!!!
Czech keys ě�čř����� work GOOD !!!
this is super
on IM+ and nICQ doesnt work
i trie the software and right after my first use.. my phone switched off by itself.... then the second time i use... i cant connect to msn....
but i can connect to icq... and to my surprised... only 3 names appeared in my list..
so i should say its not a great software(for me)
got it from the creator, but i don't know how to use it 😞
works fine for me, but on the other hand i dont have a bunch of junk installed.
i have im+ and much better than this and i don�t buy just looking egroups in yahoo :P
[quote="andredias_"]i have im+ and much better than this and i don�t buy just looking XXXXXXXX :P[/quote]
Tsk .. some people just do not want to understand the rules eh?
i'm getting some fail when i try to log on, or else nothing happens... Damn enoying... et work'd for 30 seconds
