Ok, I need help... I have Smart Launcher installed on my phone and every once in awhile when I turn the phone off and turn it back on I always get a system error message. I end up uninstalling it from the phone. Has anyone else had this problem? Am I supposed to turn the Launcher off before I turn off the phone?
Smart Launcher Issue?
YES,i had such bug,and Smart launcher killed my N3650 :black: ,but i unistalled it all is ok now :fadein: :bday: .I am not going to use Smart launcher anymore.
@jimmy-floyd: You've had a problems with Smart Launcher because you've used ilegal/cracked/pirated version of Smart Launcher.I've been using it for a long time now(since the first beta release) and never had any problems with it.
You don't need to turn off SmartLaucher before you turn off your phone.Get the latest version from www.symbianware.com.
I WANNA say that,i also used NOT cracked Smart launcher and i have got system errors.. :-?
Darla, system error message is too common one, it doesn't reveal what's really going on with the program. To solve the problem I need more details. What version of SL you had installed? Was the installation process ok? Did the problem appear right after the installation or some time passed? Haven't you tried to delete any of SL files?
I have to mention that browsing the forum is a hobby for me, not work, so if I have too much work I just look through the topics without posting. If you really want help with this software please contact me with more details at [email protected]
Jimmy, if you liked the program was it really difficult to write an email to the address above describing the problem (if you wanted to continue using the program, of course)? :roll: My sister says you're quite familiar with the email staff 😃
Well, i have no problems (just installed SL). I have reboot phone many times already and no system errors.
Hera, where do i put those skin that want to use on SL?
Edit: never mind, figured out.
I LOVE sLauncher!
I have never had a single problem with it
- in fact it recovered my phone for me once when it would not boot and the 'normal' menu system was not working 😊
It was able to get me to my applications from where I could run a restore from my MMC and fix my phone 😊 😊 😊 😊
I immeadiatly bought it, the only small downside is that it runs in the back and quite often give me low memory messages in Oplayer if I forget to quit it first.
GREAT PRODUCT!! 😊
Opps - that was me above - back on my machine now where I am logged in 😊
DARLA. Are your sure your problem was not caused by a very simular product called Wildskins?
This causes the problems you explained...
Will
No it wasn't WildSkins. The software the I was using was a trial that I got from Handango's website.
