Can i move my messages (including inbox, sent msg, outbox and draft) from my phone memory to my memory card?
I transfered an MP3 file (converted to wav file) from PC suite to my 3650's mem card, but i don't know where it went. I can't find it in \\Extra\Recording\. Pls help.
instead of MMC u can transfer ur messages to PC by using MessageSaver..
[quote="i) 1 j2 t"]Can i move my messages (including inbox, sent msg, outbox and draft) from my phone memory to my memory card?[/quote]
go to messages, options, settings, others (scroll down to find this) and change the third option which should be "memory in usage".
how did you send your mp3 to your mmc? pc suite?
you can use pc suite to find files. right click on the mmc card icon, and select "find...". you can also use a file manager to find any file you want in much the same way as you do in windows.
Thanks for your help guys! 😃
