Game with files ext ..jad/jar
8 replies · 2,754 views · Started 27 June 2003
Copy jad and jar files to any folder(up to you),and via Nokia PC suite>file transfer,transfer *.JAR file to a folder on the phone:PHONE MEMORY>INSSTALATION AND JAVA.
Thank alot 😊 😃
Hmm.... I really like this forum veri much :angel: 😉
I cant locate the jar file frm the zip file
Wat I do is I transfer the zip file to Installation-java files and frm there i reNAME it but when I install the game in the phone , It install almost to the end then it show this error "Removing......Unable to install file :agrue:
OK,as i understood you have ziped game,and there are a lot of files in there.Just after transferring it to a phone,rename for example file MOTOGP.zip to MOTOGP.jar,on your comp and transfer it on your phone..
