Right i did a sync it crashed and then after the next sync i have double of all my contacts!
Deleting lots of contacts at once
[quote="KayonLord"]Right i did a sync it crashed and then after the next sync i have double of all my contacts![/quote]
It might be easier to delete all contacts within your PIM, and then re-synch. That should leave you with one of each contact on your phone and PIM.
Though I'd backup the contact db on your PIM first!
Or u could go 4 contacts control
http://www.my-symbian.com/uiq/applications/applications.php?fldAuto=194&faq=39
will allow u 2 delete loads a contacts at once
