I have Doris Browser 1.15 installed in my Nokia 7650 but I am not able to access sites only I can access is my service provider wap site........other than that I am not able to connect. On the other hand, through inbuilt Nokia 7650 Browser I am able to access each and ever wap site. I have also tried Opera Browser but the same problem. Can anybody tell me why I am not able to connect through my Doris/Opera Browser???????
Doris Browser Help
You're trying to connect to the internet right?
You have to use internet GPRS, not wap GPRS.
Meaning internet GPRS settings.
Check your operators GPRS settings.
If you're using GSMdata, check GSMdata settings.
Yes I am using Wap GPRS.But then why in-built Nokia 7650 wap browser is working properly??? Through that browser I can access each & every site. [quote="akshay"]I have Doris Browser 1.15 installed in my Nokia 7650 but I am not able to access sites only I can access is my service provider wap site........other than that I am not able to connect. On the other hand, through inbuilt Nokia 7650 Browser I am able to access each and ever wap site. I have also tried Opera Browser but the same problem. Can anybody tell me why I am not able to connect through my Doris/Opera Browser???????[/quote]
[quote="akshay"]Yes I am using Wap GPRS.But then why in-built Nokia 7650 wap browser is working properly??? Through that browser I can access each & every site.[/quote]Because the built-in browser is a WAP browser using WAP protocols through a WAP access point.
Doris an HTML/web browser using HTTP and TCP/IP and needs an IP/internet access point.
Thanks for the Information. But now I am in deep trouble, I am not able to access any site (which I could earlier) through my Nokia 7650 default browser.....every time I try, aftersome time it shows me "wap: connection time out" excpet one site that is 'Nokia software market'. Could you pls tell me why is this happening??? & how can I get it correct????? I hv already checked my gprs settings..... I hv also download settings again from my service provider. But still facing the same problem.
PLZZZZZ HELP ME OUT !!!
Check your bookmarks and see what access point they're defined to use. If default, then check that the default access point settings are correct.
You should also be able to call your operator's customer service for instructions regarding the correct settings.
I hv already done everything.........but could not help me out.There is some real problem. I think my Nokia browser WML files are overright but HTML files ! Is it possible??? & if yes then how can I get it correct?
