How the hell!?
6 replies · 2,577 views · Started 27 June 2003
Assuming you have got the phone down to the LCD layer (by unscrewing various layers)..........
What you need to do is put the phone face down, take a small screwdriver and slide it down one side of the cover until you find the clip that holds the cover on (roughly half to 2/3 of the way down).. Then you need to gently start prising off this side of the cover (possibly need 2 screwdrivers for this). Once you have done this you may need to give the other side some gentle encouragement et voila! you have removed your cover...now you can get rid of all that dust!
good luck
I have one for sale if anyones interested.
Official Nokia Fascia Removal Tool! I bought it so i could easily put my brand new replacement fascia on.
hey euphoria, can you tell me where you got your new fascia from? i've been looking for one for ages...
I got my Fascia off e-bay! I had to buy the tool as well otherwise i would have struggled and snapped most of the fittings!!
Big APOLOGY for the late reply! Hope this helps.
Incidentally i will sell the tool and spare (a couple of small marks where the colour has worn away) for �15 plus p&p, Fascia is good for custom paint job!!!!!
Let me know!
